Hi so I would greatly appreciate some help figuring out what?s going on with my car.
So, there is a misfire on cylinders 4, 6 and 8. The spark is weak on those cylinders and a noid light shows every injector is seeing a signal from the PCM. So far I have replaced the plugs, wires, ignition coils, a few injectors and made no change. I thought it could be the PCM so I used the VCM suite to load my tune onto a new computer and the misfires followed it.
My car uses the Turbonetics T76 turbo kit as well as a mild cam good for boost and all the supporting mods. The car was tuned on e85 by Levin Motorsports in FL but it doesn?t use a flex fuel sensor. So my problem started after I couldn?t get to e85 and ran 93 through it. It starting misfiring and flashing the stabilitrac message, so I reset the computer by pulling the neg battery terminal. That temporarily made it run well but then within a week, resetting the computer made no change.
Can anyone please tell me if it?s possible that I corrupted the tune on the car?? Because I am at my wit?s end and don?t trust any shop to work on the car aside from the shop that did the tune and I live 3 states away from them.
