was trying to set up a histogram for ve tuning on my 2000 s10 with the L4big pcm and noticed first off theres like 4 areas within the main ve (idle,high rpm,low rpm double fire,low rpm single fire,and low rpm coastdown) and if that wasnt confusing enough,the idle and low rpm coastdown ve graphs are in kpa x rpm which I'm familiar with and understand,but the high rpm,low rpm double fire and low rpm single fire graphs are in throttle position x rpm..which kinda confuses me a bit..after a bit of research I found this is a "alpha n" tune (news to me lol) so my questions are,which portions of the ve do I actually need to tune(high rpm,low rpm single or double fire)? and how would I set up a histogram/tune the ve portions measuring in throttle position x rpm(high rpm,low rpm single/double)? I attached some not so good pics showing what I'm referring to as well as the tune file.. EDIT
s10 ve2.jpgs10 ve1.jpgs10 ve.jpgs10 ve 3.jpgs10 ve4.jpgs10 ve4.jpg s10 tune.hpt
