In working with the very responsive guys at HP tuners. I have these additional parameters found and added to the E67/E38 ECMs. Many of these will also work with others like the E40 and E92. I have focused on the ECMS that I most use and I have not tested and validated the other ECMs. These are defined in Beta 3.7.9.50 and later. Most, if not all, will not show in your OS unless you request them or until the software hits production. I have also identified and am working on the items required to adjust the Speedo for staggered systems.
Found in OS:
2012 Chevrolet Camaro ZL1, 6.2 L, 8 Cyl
Hardware: E67, GM Gen4
OS: 12652955
12940 - Requested Airflow Low Barometric : g/s @ rpm vs tb blade position used in TQ, idle and predictive airflow
12941 - Requested Airflow Medium Barometric : g/s @ rpm vs tb blade position used in TQ, idle and predictive airflow
12942 - Requested Airflow High Barometric : g/s @ rpm vs tb blade position used in TQ, idle and predictive airflow
45681 - Pre Cat Lean Thresh
45682 - Pre Cat Rich Thresh
45683 - Post Cat Lean Thresh
45684 - POSt Cat Rich Thresh
13545 - Urban Throttle Progression
13541 - Minimum Rail Pressure
13542 - Maximum Rail Pressure
12467 - Closed Loop O2 Ready ECT vs. Startup Delay
2532 - O2 Sensor Not Ready Timer
2401 - Power Enrichment Ramp Out Rate
4160 - Oil Temperature High
4161 - Oil Temperature High Hys
14110 - Oil Pressure Minimum
4152 - Oil Press Warning Delay
4151 - Oil Pressure Low Delay
4150 - Oil Pressure Low Hys
315 - Axle Max Torque Limit with Spark Time
316 - Axle Max Torque Limit with Fueling
317 - Axle Max Torque Limit with Throttle
321 - Clunk Reduction with Spark Timing
322 - Clunk Reduction with Fueling
323 - Clunk Reduction with Throttle
2803 - Traction Control RPM Enable
2804 - Traction Control RPM Disable
2805 - Traction Control Runtime Enable
12582 - Torque Loss Runtime
2424 - Power Enrichment Mode Throttle
2425 - Power Enrichment Mode Throttle Bypass Delay
2426 - Power Enrichment Mode Speed Bypass Delay
2427 - Power Enrichment Mode Upper Bypass Delay
2428 - Power Enrichment Mode Lower Bypass Delay
2464 -Power Enrichment Mode Timer
2520 - Closed Loop Blend Time
12944 - Closed Loop Blend Time 2
12945 - Closed Loop Blend Time 3
12530 - O2 Sensor B1 R/L vs. Airflow Mode - (Fixed were mapped to wrong location prior to current beta)
12531 - O2 Sensor B2 R/L vs. Airflow Mode - (Fixed were mapped to wrong location prior to current beta)
28940 - Closed Loop Temperature Threshold
2532 - O2 Not-Ready Timer
24991 - O2 Ready Timer
45011 - O2 Sensor Upper Limit
45013 - O2 Sensor Lower Limit
44003 - Enhanced RPM In Closed Loop
44004 - Simplified RPM in Closed Loop
14072 - Misfire RPM Test
7977 - Small Pulse Cranking
45524 - Injector Off-Time
34971 - MAP Estimated Max
34972 - MAP Estimated Min
2994 - MAP Error Check 1
2995 - MAP Error Check 2
3066 - RPM Zone Change
3067 - RPM Zone Change with AFM
3079 - MAP Zone Change
3080 - Zone Change MAP with AFM
10985 - Airflow Prediction 1
10986 - Airflow Prediction 2
11009 - MAP Filter Coefficient 1
11010 - MAP Filter Coefficient 2
3034 - Airmass blend
15040 - Intake Cam
15041 - Exhaust Cam
15009 - Map Filter
11051 - Delta Map
12009 - Minimum Coolant Temp Allowed for Purge
12099 - Open Loop with Purge
25012 - Low Flow Duty Cycle
25013 - Mid Flow Duty Cycle
25014 - High Flow Duty Cycle
4112 - Baro Sensor Gradient
4113 - Baro Sensor Offset
5018 - MAP Sample
5019 - MAP Filtering
4117 - Rev Limiter Enable
4118 - Rev Limiter Disable
8109 - Octane Scalar
2708 - Knock Up Learn Thresh
2196 - Idle Adaptive Max Vss
2197 - Idle Airflow Mult vs. Baro
2330 - Flood Clear Enable TPS
2331- Flood Clear Disable TPS
18698 - DFCO RPM Delta
