Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Why is it a mystery on how to make E fans work
  1. #21
    May 2017
    21
    The radiator coolant temp sensor. I found in the scanner and it read 32*all the time so I'm not sure if there need to be a temp sensor hooked up somewhere.i look up the wiring and check it out
  2. #22
    May 2017
    21
    nothing
    nothing
  3. #23
    Jan 2014
    Australia
    1,983
    it should just work of the coolant temp sensor which is reading fine, not sure why none of the fan pids are doing anything very odd but i guess that's why is not turning them on, that desired % pid needs to work, if does need an extra sensor then there might be am input in ecu could even test it with a resistor if u know what range it works in and usually is just a 5v reference thru resistance to input and see if those fan pids work or even use a 50k trimpot so u can adjust it see if it changes
  4. #24
    May 2017
    21
    Hmmm where would this input be?
  5. #25
    Jan 2014
    Australia
    1,983
    not sure could even be just in the data from the ect sensor, may be easier to fit a separate fan controller to run it with its own sensor, maby yours being mechanical in the beginning has something missing unless there is a slave segment swap u can do for it
  6. #26
    Oct 2014
    9
    Ever make any progress on this?
    I know the 2016 Suburban 3500 with 6.0 has efans, and same ecm p/n (e78) , but there isn't a stock tune in the repository.
  7. #27
    Jan 2020
    1
    Bringing this back up. I'm trying to add e-fans to a 2012 2500HD and I haven't found one success story for anyone using the E78 ECM.
