Results 1 to 5 of 5
Thread: Spark/Retard - Static Retard vs Cylinder
    Jul 2015
    8
    Hi Team.
    LS7 (C6 Z06 2008 E38)
    In the editor under Spark/Retard there is a table for retarding ignition timing per cylinder = Static Retard vs Cylinder
    The cylinders table is set up as below:
    #0
    #1
    #2
    #3
    #4
    #5
    #6
    #7
    So I asked Hp-tuners which of above is cylinder 8. And they do not know. Do you guys know?
    Merry Xmas!
    13,564
    I thought I had read long ago that it's based off the firing order.
    0 is the first cylinder that fires and then it just runs down the list to 7. Don't quote me here though as I've never bothered to try and tune that on a E38.
    Jul 2015
    8
    Yes I have the same guess as you. But can some one confirm?
    anyone?
    May 2016
    Adelaide, Australia
    246
    Wouldn't be hard to figure out.
    crank up the retard on one cylinder to the Max and check with an infra rwd thermometer the header temps.
