Hi
i have a AEM 30-0300 Wideband But it doesn't work with HP tuner , i read it is need to new firmware
so anyone can tell me what i need to get it updated please
Best
Hi
Best
2011 Camaro 2SS A6 GMP car /JLT CAI,HHP custom camshaft, ported heads, BTR 660 dual springs, SA GEAR double roller timing chain, VVt DoD delete, ported intake manifold, nick williams 102mm TB, FLUIDAMPR 25% UDP, 160 thermostat, BBK 3/4 LT, x pipe , cutout , 3.45 diff, BMR 3 points strut bar, NGK TR7xi
The firmware change is only needed if you want to connect the wideband to the vehicle's OBDII bus. You can connect the analog output of the 30-0300 to the A/D inputs on the MPVI pro interface, like any other wideband.
