Thread: 03 6.0l trans tuning Tcm or Ecm
    Dec 2012
    235
    On the 6.0l, I have a customer with a 24v Cummins with a P pump swap. Problem is with the Cummins, the stock Ford shift points are obviously wrong. Can I adjust trans functions on this 03 6.0l through the tcm, or do I have to do it through the ecm? So if it is seperate through the tcm, I'm assuming I can license the Tcm seperate from the ecm?
    Tuner qwkvert's Avatar
    Nov 2014
    Melbourne, FL
    61
    Tcm. Yes, you can license it separate.
    Dec 2012
    235
    Perfect. Thank you.
    Nov 2014
    Melbourne, FL
    61
    no problem.
