Hey guys,
So I?ve read everything I can on Driver Demand and Peak Torque tables. I think I get what I need to do, but would like some clarification.
My real question is: Do the usual changes apply to a stock car? I?ve noticed big differences in throttle % and boost depending on conditions, temps, heat soak, etc. On the dyno the other day (making baseline pulls), everything looked normal. But it was warm out (81 degrees) and the blower was hot from a long drive (~150 degree starting manifold temp). Timing and power were down some, but throttle and boost were what I expected.
Fast forward to yesterday...and things were much different. The motor and ambient temp were cool. Timing was much stronger, but I?m greeted with erratic throttle and only 7-8 psi of boost because of it.
Do I just need to tweak the DD table, or does the Peak Torque table need adjusting as well? I haven?t added any power, so I?m questioning whether Peak Torque should be changed.
I found some good threads on this, but they really all apply to modified cars. I do have an intake on my car (no tune needed? supposedly), so maybe that?s contributing to my throttle closure. I don?t like messing with MAF tables without a wideband, so I haven?t touched it yet. It was pretty rich on the dyno, so I may take a little out.
Thoughts and opinions welcome!
