Results 1 to 6 of 6
Thread: 4L80E wont shift into 6th at WOT
    Mar 2015
    gippsland
    134
    hi all.
    I know the reason the vehicle wont shift at WOT into 6th due to the tables being maxed out to 383KMH but is there any reason Gm did this?
    and is it safe to lower this back down on all WOT shifts to enable top gear?
    Vehicle is a track car 2014 VF ss 6.0L, with T43 trans controller.
    13,564
    My theory is that the cruising 6th gear in a 6L80e is not made for super high torque/load.
    This must have some pretty crazy rear gears if you already see 6th gear on a track.
    Mar 2015
    gippsland
    134
    he has 3.9 gears, and will max out in 5th at 237kmh.
    Mar 2015
    gippsland
    134
    ok so update, we have attached tune file and still no WOT shift into 6th in both sport pattern and drive. dash flashes "shift denied", to enable shift you have to come off the throttle.
    the only tables i didnt touch were the safety shifts which i had only just noticed after getting home, could this be the cause?doug VF MOD2.hpt
    Mar 2015
    gippsland
    134
    any guidance would be greatly appreciated as i have to travel 4 hours to see vehicle.
    Jan 2004
    Perth - Western Australia
    276
    you'll never get it to shift into 6th above 230kph is my experience.
    you can be in 6th in manual mode and as soon as you hit around that speed it will automatically downshift to 5th. Ive even tested this on a 2 post hoist, does the same thing.
