Can anyone confirm which pin the E39 ECU uses for VSS signal input? I have the 2012 GM Fbody service manuals, the manual transmission VSS circuit schematics indicate pin X2 43 but the ECU chart in the same set of manuals indicate X2 43 is for the MAP sensor signal! It's rather cold out to trace circuits with a multi meter.
My ECU is an E39 from a 2012 Camaro, engine harness I'm using was also for a 2012 Camaro, manual transmission.
The LFX engine is swapped into a Suzuki Samurai and has a mechanical speedometer driven off the T-Case so I don't need the VSS signal for the speedometer. I completed the swap a couple years ago and other than setting the default trans limit to 1000 and maybe a couple other things to get it to REV to the red line haven't really done any other tuning but probably should. With the tune as is it's stupid quick for a lifted Samurai but some proper tuning should refine it a little...
Once I get into tuning it would be nice to have vehicle speed readout for logging etc..
Thanks!!
