Hey everyone,
This is in a 1965 Mustang w/ the low compression FRPP 5.0L and T56 trans. 58mm turbo's and 50mm WG's. ID1050x inj's w/ aeromotive pump and regulator, set @ 50 psi w/o vac., referencing vac. & boost. eBoost 2 contoller set for 6psi, 9psi and trying to get 12psi, once this issue can be fixed. This is running that awesome 91 octane in Cali so, wtr/meth will be added on soon.
I applied alot of the Cookbook changes and ran the veh. on our Dyno Dynamics for the driveability side and a few wot pulls before moving onto the Dynojet. The power and tq are great until 5000 rpm, they start to fade sooner than I'd expect. I did runs with only OP table and then with all the orig MP tables, but no difference. Both dyno's showed the same lack of performance.
Any thoughts to cam angle or torque model/mgmt areas I need to look more into? Maybe I messed up or forgot something somewhere. I guess I just need another set of eyes!
I'm attaching the file, log and dyno runs w/ 6, 9 and an 11psi attempted run.
** Can someone verify which knock retard is the one to correct for i.e. pos or neg, I remember reading a post that it is backward in HP and then it was or wasn't fixed later on?
** Also have a stalling issue on decel after a run with the clutch pedal down, if anyone can help on that too.
Thanks,
Jason
1050x _wot dynojet_WG change_12psi boost_113.hplOHY_ID1050x_114.hpt20180110_163207[1].jpg
