So odd just meant it doesn't seem like the numbers in the row you added correlated well to the row before it in the table. Since you're having issues with torque/air load request I'd be more comfortable if those blended in better.
Here's the method I used when redefining the torque tables. This is not the 'correct' way to do it as that would definitely involve a load dyno and a log, but this was my compromise with tools I had available to try and guesstimate the values. I also wanted to keep as many factory 'good' values as I could, so instead of just relabeling the max air load row I deleted a row in a section where there was more 'resolution' in the table, but was still far enough up the range that having a larger jump between rows shouldn't affect normal drivability much (from my testing I haven't noticed any difference at all relating to the row I deleted).
So here's what my tables look like, and the row labels with a decimal added, and then attached is the spreadsheet I made to get my values for the 2.5 load cells. The first 2 tables I verified each value going into the 2.5 cells, then for the rest just copied the values in. A slightly better way would probably be to cross reference the mapped points you hit at WOT and verify the cells you will actually be hitting have values that look good to you.
I did the same process to populate the new cells in the IPC torque max table. These are from a '16 2.7l F-150 just FYI.
