Results 1 to 5 of 5
Thread: Wgate DC
    Aug 2016
    Thunderdome
    389
    Wgate DC
    To control boost spike & allow for a smoother boost transition, are those two sections the appropriate correcting areas?
    I have a burrito in my colon, yet refried beans come out...
    How i know it's from the same meal? I didn't ingest corn any other time.
    Aug 2016
    Thunderdome
    389
    Is there anyone that can help?
    Aug 2016
    Thunderdome
    389
    no one knows?
    Apr 2014
    706
    Your Proportional Gain and Integral Gain, along with Transient Adjust tables are going to be the ones you want to focus on, unless you've changed the spring rate in the wastegate actuator. The base table ("WG DC (RPM)") is calibrated for the spring rate that came factory with the vehicle, and should do a pretty good job of keeping boost on target over the broad range, but the other aforementioned tables are what will make quick changes to compensate for boost fluctuations, including transient conditions.
    Aug 2016
    Thunderdome
    389
    thank you, that I probably would have not figured out so simply using hpt.
