Results 1 to 6 of 6
Thread: 2017 GMC Sierra Cruise Control Issues
    Jan 2018
    2
    Truck is all stock except for a small lift and has 35in tires. I used the gear/tire wizard to adjust the speedo and now cruise isn't working. First time I've had this issue. Any ideas?
    13,565
    What if you set the tire size back to stock, does it still do it?
    This would rule something out if nothing changed.
    Jan 2018
    2
    Was planning on giving it a try when I got a chance. Honestly not even sure that it worked before the change.
    Manually adjust the VSS tire Revs per. Its usually +/- 3%.
    Oct 2008
    4
    Did you get this figured out? I am having the same issue on a 2017 Silverado with 35" tires.
    Nov 2018
    West Coast
    196
    Any solution?
