Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: Needs to crank twice to start, even just a little "blip" and it goes
  1. #21
    Feb 2017
    miami
    1,799
    Okay how about this. Today it only did it After I uploaded a tune, it does this, Sometimes.
    Cranking -> forever. Nothing. I can crank 30 strokes or 3. it doesn't matter. Just one little blip.
    Stop cranking.
    Re-crank: starts on 4th compression stroke.
    I haven't had it cranking -> forever until I upload a new tune. I guess I can live with that.
    Is there some kind of wire that is active only when engine cranking? SR20 have that. If you don't put 12v to that wire when cranking it does the same or similar thing... sometimes
    Update: I am going to try a momentary switch on the crank trigger that I can manually trigger before actually cranking.
  2. #22
    Feb 2017
    miami
    1,799
    I get it to fire every single time now. Pretty sure what finally did it was the prime pulses. I kept increasing master prime, prime1 and prime 2 until it just starts immediately on the second or third stroke. I think its even a bit too much fuel now because one time my hand slipped off the key and it tried to start from just 1 stroke, starter is also dying so it turned really slow, sputtered a couple then stopped. Then re-cranking it was flooded, had to clear flood. So I think now what I want to do is reduce cranking table post-prime until it never floods.
    Loving all these settings. should update my other threads to I've learned quite a bit
    update1:
    I returned the "FA cranking table" (what does FA stand for?) back to stock,
    and pulled a bit of fuel out of everything and it still starts pretty good with just .1g in master prime (the key-on prime) and I think .1 or .2 in the first fuel pulse mass table also.
    What I like to do is let it go 2-3 compression strokes (.2-.4 seconds of cranking) and let go of the key, it just sort of lags for a moment like its not going to start, then rumbles to life nicely.
  3. #23
    Nov 2022
    2
    Quote Originally Posted by kingtal0n View Post
    update1:
    I know it's old, but I am having this same issue. I will try this, and I just wanted to say: Thanks for updating!!
  4. #24
    Jan 2015
    Arizona
    437
    I get it to fire every single time now. .
    ive got a customers 2003 tahoe that does this.
    will not start on 1st try. Owner's mad becuase he cant use his 'remote start'
    2nd time cranking and will fire right up.
    I'll look for 'master prime'..
  5. #25
    Potential Tuner 5_Speeds_in_OKC's Avatar
    Jun 2023
    OKC
    8
    My 2003 2500HD 6.0 exhibits this same behavior. On the first crank cycle it won't start and will backfire if you keep cranking it. On the second crank it immediately starts. I have monitored fuel pressures -- they're right where they're supposed to be. No codes point to a potential culprit.
    In the research I have done, someone, somewhere commented that these old PCM's have underperforming capacitors (as they age). In a nutshell, during the first crank cycle, a particular capacitor doesn't have enough residual energy stored in it, so isn't doing what it's supposed to do, but it gets a charge during that first crank cycle, however brief it may be. On the second crank cycle, that capacitor has some 'juice' in it so it can properly energize whatever circuit it is tied to. The only remedy for having old capacitors is to get the PCM rebuilt.
    I just live with it...
    ~~~~~~~~~S~A~V~E~~T~H~E~~M~A~N~U~A~L~S~~~~~~~~~~~~ ~~~~~~~~~~
    Cargo/Trailer Hauler: 2003 Chevrolet Silverado 2500HD WT RCLB LQ4 NV4500 RWD E-Fans
    Family Hauler: 2003 GMC Yukon XL 1500 SLT L59 E-Fans NV4500
    Daily Driver: 2010 Toyota Camry 2.5L 6-Speed Manual
    Daily Driver: 2011 Toyota Camry 2.5L 6-Speed Manual
  6. #26
    Feb 2017
    miami
    1,799
    backfire on first crank is a bad cam sensor
  7. #27
    Jun 2023
    OKC
    8
    Interesting thought on the Cam Sensor; however, if the Cam Sensor were faulty, wouldn't we expect a Code to be triggered?
    Could it simply be time for a Crank Relearn?
  8. #28
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by 5_Speeds_in_OKC View Post
    Not every time will it throw a code, part store sensors will sometimes not throw a code and still be at fault. Get an ACdelco sensor and you’re problem will go away
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
  9. #29
    Feb 2017
    miami
    1,799
    Make sure you have the correct cam sensor voltage and pinout
    And correct wiring orientation
    guessing you are gen3 but just in case I show both
