Results 1 to 2 of 2
Thread: Missing PID for Toyota 86.
    Dec 2019
    I?m running TrackAddict Pro v.4.4.3 on an iPhone 11 running iOS 13.3.
    I have run this app on iPhone 7+, and iPhone X running iOS 11 and 12.
    I am using a PLX Kiwi3 via BLE protocol from the car to the phone. The same device that HPTuners recommends for iOS devices.
    I am using this setup in a 2013 Scion FR-S (Toyota GT86), that has been tuned with OFT.
    I have contacted HPTuners directly about this issue, and have received no support, so I turn to the community.
    Why can I not monitor oil temp through TrackAddict?
    I can monitor that PID through many other apps (Kiwi, DashCommand, etc.), however when using TrackAddict, that one PID is completely missing.
    What is required to correct this?
    May 2014
    USA
    450
    oil temp isn't a standard "mode 01" sae PID, and as far as I know TA doesn't support custom PIDs yet. Those other apps, if I had to guess, probably have a few common extended PIDs programmed into the app and just recognize your car and give you access to oil temp.
    Development for this app has seemed to slow down quite a bit (other projects perhaps?), but you'll find that other track app offerings do support custom defined PIDs.
