Results 1 to 14 of 14
Thread: Deka 80lb injectors
    Nov 2017
    25
    Deka 80lb injectors
    I hope its ok that i post this..If you buy the deka 80 injectors do they come with the injector data or do you have to download it? I bought some off of Ebay and the seller said that they were deka siemens but im thinking they are knockoffs
    13,564
    They don't come with data, that's kinda why they are so cheap.
    There might be some posts throughout the forum with data to try or maybe someone has something.
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    If you go by what Injector Dynamics says. It is all in the work of the company that sells them. So E-Bay puts no work into the injectors so that is what you get ... no value. By ID or FIC and you get support. Buy EBay and you are on your own. Bad deal for buyer.
    Nov 2017
    25
    thanks guys
    405
    2,321
    I've used this data with them and they tune just fine.
    Nov 2017
    25
    Quote Originally Posted by 2xLS1 View Post
    So 300 kpa would be 43.5 psi fuel pressure
    13,564
    Yes, and then if you are running the factory 58psi of fuel pressure it will be different.
    His file already has it set for 58psi as the flow rate is higher than 80 already.
    405
    2,321
    And just to be clear the tune file I posted is not one of my tunes. Just a tune file that was posted on LS1Tech that supposedly had good Deka 80 data in it. I've used that exact data in vehicles using those injectors with good results.
    Would it be best to input all of the injector data and getting the car to idle and normal drive good with the injectors before i start to tune for boost?
    May 2016
    Adelaide, Australia
    246
    Quote Originally Posted by BoostedRedneckMFG View Post
    Well yeah.......
    Apr 2021
    1
    what about 2010 n6.2l e38- flex? i have these injector in and trying to get this data interred- everyone has a 5.3 and not gen 4or5?????
    so my options are diffrent then what im seeing on goat and other ppl when doing the data..
    Sep 2013
    427
    .....Agree 2XLS1 used same data with the 80lb and yeah tuned them fine, gd work
    Sep 2021
    Oregon
    38
    Do you still have this data?
    Advanced Tuner Matt Vardaman's Avatar
    Mar 2021
    207
    Quote Originally Posted by Sjd6795 View Post
    Look at post #5 it's still there.
    2001 Silverado 5.3 - 209/217 cam, GT45 Turbo on 7lbs, Aem x-series wideband, 50lb/hr flex fuel injectors, on E85 with content sensor
    1999 Silverado 6.0/4L80E Summit Stage one camshaft, 317 heads (replaced cast iron)
