Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
Thread: Unlicensed Interface
    28,265
    Quote Originally Posted by powerofdreams8 View Post
    Ive made the mistake of emailing several times, but it been 10 days now. In previous scenarios it has been remedied very quickly. My customer is NOT happy. Pls someone at HP pls help me out!
    What is your ticket number?
    Mar 2015
    36
    This is the issue with email tech support. Too easy to fall through the cracks. Often very hard to explain a issue in text. Good Luck.....
    28,265
    Quote Originally Posted by Cobradoc View Post
    Which is why we offer teamviewer sessions when necessary. Only about .1% of our tickets will ever require that level though.
    Brisbane, Australia
    159
    Quote Originally Posted by Ben C View Post
    How?
    My guess is he typed the application key in wrong, possibly using zeros instead of O's
    I had the same issue with mine when I went to license mine.
    Oct 2014
    48
    I was having the 'unlicensed vehicle ' issue too. Tried re-sync'ing but to no improvement. Read several threads and saw something, so I tried it. It worked.
    My normal car is a 3 bar Speed density turbo'd 5.3 in a 96 z28. I've been using HPT on it since 2015 or so.
    My friends car is a 1 bar stock type 5.3 in a 1980 Trans/Am. I put the engine together and installed it for her. I bought 2 credits for this tune and it could pull the current tune and I could modify/save it but could not upload. It would simply say, "Unlicensed Vehicle" and never presented the option(s) to license the new PCM or to use the credits, etc. So in the article, it mentioned
    ( a ) copy the lastest application key for HPtuners (highlight, CTRL + C)
    ( b ) Hook up your dongle (HPTuner device) to your laptop using the USB, doesn't need to be attached to the vehicle at this point.
    ( c ) Open the editor, click 'Help', then click 'MPVI' application Keys.
    ( d ) A drop down box appears where , towards the bottom, your current Interface ID and Application Key. To the left of that is a reddish in color fat minus sign. When you click on the Minus sign, it deletes the Interface ID/Application.
    ( e ) paste in the application key you copied on step ' a ', then click 'Add Key'.
    ( f ) exit.
    After I did that, I took my laptop and harness/dongle out the the T/A, hooked it up, turned on the key, made sure the scanner still worked/read, the went to the editor and clicked 'write'. NOW the license dialog popped up and I was able to select the write. I had to take the option to 'write entire' to go forward but I got it uploaded. Afterwards, cycled the key, started the scanner, cranked her up and she fired up right off the bat.
