Originally Posted by
MMGT1
Not a clue on that one, it jumped out as really odd to me. I have had this PCM do strange stuff. It doesnt seem to flash properly unless I sit in the truck. Every accessory off, and with key still in the off position, hook up the dongle. Editor open and ready to flash. Key on, hold breath for a few mins and when it done, close out editor before key off. Remove key, open and close door, then start and scan. Seriously, Ive had weird stuff happen flashing this PCM, not going into PE at all and then with the exact same file flash in order as I said there, and it acts fine. I have no answer for it at all, just know what works for mine.
Edit: Also try lowering your Cylair Max Multiplier to 1.95, it should be set slightly lower than the WOT Multiplier and would also set max load in speed density to 1.8 or so replacing the 1.0 you have.
