Results 1 to 17 of 17
Thread: PR logging Value issue
    Sep 2010
    Houston
    131
    Hello Guys
    Im running into weird logging issue IDK if PR is defined correctly for NGC4 ecu 2010 SRT8 for some reason the PR value does not go above 1.0 under boost I can read 128KPA absolute base on the 82kpa Atm/Pressure that will put me in the 1.31PR value I attached a log.
    Apr 2014
    704
    Quote Originally Posted by GCtech View Post
    Hello Guys
    Have you increased the PRatio Max parameter in your tune, found under [Engine] [Airflow] [General] [Pressure Ratio Limits]?
    Jul 2015
    925
    post your tune.
    Sep 2010
    Houston
    131
    Calibration Attached with a recent Log as well
    BTW the PR max is set at 3
    Jul 2015
    925
    You BARO sensor PID changes from 81kpa to 157kpa. I don't think it's supposed to do that...it should read around 100kpa and shouldn't change.
    Jul 2015
    925
    The PCM uses the BARO sensor along with the MAP sensor to calculate P ratio
    (Barometric Pressure + Manifold Pressure) / Barometric Pressure = Pressure Ratio.
    Jul 2015
    925
    Is your MAP sensor data correct? It's been a while but IIRC, sensed MAP should be enabled and BARO learn should be disabled.
    Hopefully someone else will chime in.
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    As the guys said, you have something funky going on with your baro readings. What map sensor are you using?
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Sep 2010
    Houston
    131
    The srt8 is not at sea level thats why Baro moves is 81-82kpa atomspheric pressure at were is currently located is 82kpa
    Im using 3 bar map sensor all data is correct , there was a map limitation to 250kpa under engine diagnose max map but support already raised the limit, I thought that was causing it but it was not.
    Jul 2015
    925
    That makes sense. However it shouldn't change. Turn MAP sensed on and Baro learn off and see what it does. With the BARO changing like that I can't see the PCM being able to calculate P Ratio correctly.
    Sep 2010
    Houston
    131
    Ohh ok ok i see what you saying now it should stay at 82kpa all the time and not increase past 100kpa 1 absolute
    I?ll turn Map sense and see what happens , i need to be able to do Baro corrections as altitude variates a lot from town to town down there just a 1.5hr drive will variate from 82kpa to 70kpa
    If I turn Baro learn off wouldnt it cancel any Baro corrections as well?
    May 2007
    Seattle, WA
    59
    Baro Learn is used to update the ECU barometric pressure *during the current key cycle*. The ECU uses the MAP sensor in the manifold (the thing that reads your boost) to update its Baro as you drive... any time you get a throttle position that is near what it expects WOT to be, it will update its baro reading based on some maths... (air filter pressure drop, etc etc etc).
    With a supercharger out there, it has no way to know that the pressure its seeing in from the sensor is the real BARO or if its boost.... It will go and update the baro to a bad value!
    It's not *perfectly* ideal, but you are going to have to disable BARO learn, and let the short term adaptives work out the fueling changes based on elevation changes as you drive. the baro update from 82 to 70 (or the other way, from 70 to 80 to even sea level of 100kpa) shouldn't really cause any trouble for you, even if its not perfectly "up to date". those are still relatively small changes in overall air present. Just get the VE table dialed in and run with it... the car will just set its BARO on key "on" like it always does. This has been this way on these hemi's since we started tuning them years ago.
    2018 Jeep Trackhawk - Blue
    What we do in life, Echos in eternity
    Sep 2008
    Portersville, Pa
    289
    Quote Originally Posted by lafrad View Post
    Lafrad - A name from the past! Sir, of all the tuners out there that I have seen tunes from (on the Hemi's) over the last decade yours by far were the best written/logically modified. Welcome back! Trackhawk huh?
    Specializing in building and tuning 1000hp, daily driven, 9 second cars!
    www.ostdyno.com Shop Phone: 724-368-9000
    Sep 2010
    Houston
    131
    Got it! I appreciate the input.
    Jul 2015
    925
    You make any headway on this? Interested in the results.
    Sep 2017
    MN
    9
    I was having this same problem on 2007 6.1. Turned on Sensed map and Baro Learn off and its reading over 1.0 now.
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    What I know is, that the 3 Bar is not working correctly with non HC PCM?s
