Results 1 to 5 of 5
Thread: fuel from wall stabilization limit ?
    Jan 2014
    Australia
    1,986
    [ECM] 2280 noticed this number now only goes from 0 to 2 and it wont allow any number higher then 2 is this a limit or a issue..? i havnt messed with it for a while but though it could go higher
    Feb 2016
    Texas
    534
    assume the max is set to 2 simply to have the ability to double or eliminate the action of this table. I've piddled with this on my truck with questionable results running an efi super victor intake. I believe i set mine back to stock. After some fine tuning of my fuel to wall impact factor table and its gain table i was happy with those results.
    97 ext cab short bed silverado 5.7 411 swap, edelbrock 29135 intake, lightly ported 906 heads milled .035 thou. factory press in rocker studs & rockers, comp 787 retainers & stock locks, ls6 springs. Comp cams 08-503-8 T56 swap
    86 SWB crate vortec 5.7/th350 The wife's truck
    Jan 2014
    Australia
    1,986
    my thinking is because the LSA injectors that spray at an angle into the port are set to 1 and my stock standard style injectors are set to 2 that this setting helps with a direct or indirect spray pattern, since i now have manifold spacers (keep the blower off the heat) that my injectors now sit a little above previous port alignment and its not as direct so this setting may have helped, looks like i might just have to change some other transients to get it better again
    Nov 2016
    6
    Are you having a problem with throttle transition? I have a lsa blower on a 5.3 with cathedral adapters and am having a lean spike on tip in. In my operating system there are very few transient tables.
    Jan 2014
    Australia
    1,986
    mine isnt too bad just since adding the spacers it has changed fueling a little bit so i was playing around with it and the eoit needed some more changes for the now increased distance away from chamber so its mostly fixed up now, just wasnt sure if i could use that fuel from wall to help changing it globally
