I am planning on modifying my HE351VE turbo soon to a larger compressor and turbine wheel (parts sourced from TurboLab of America). I am trying to think through what will need to be modified to properly use the increased airflow (both intake and exhaust). Under the airflow tab, there is the MAF Calibration, Fresh Airflow, and Charge Airflow tables, along with the Compressor Map efficiency and Comp. PRatio. Should these tables be changed to what the new compressor wheel "might" be (no compressor map), or just change the fueling table to account for the increased air mass available (also a guess)?
On the topic of the turbo, what parameters control the vane position? There are the tables to set the min and max position, but no real clue what the ECU is using to set the vanes. I know that back pressure is a variable, but there does not appear to be a place to change the allowable back pressure (there is the exhaust brake max torque table). I would like to increase the allowable back pressure, as I have 110lb valve springs, so I could potentially have a stronger exhaust brake.
Thanks for any input.
Cheers,
Jared
