Results 1 to 8 of 8
Thread: Revs hang?
    Aug 2017
    17
    Revs hang?
    Hey guys, I've noticed on my 17 Silverado 5.3L the revs hang for awhile after a hard rev. I know this has been discussed with the Gen III/ IV stuff but is there a fix for this on the Gen V? Thanks in advance.
    Jul 2018
    10
    Interested in hearing if there is too. I believe you can just something in idle controls, but I don't know which parameter.
    May 2003
    South FL
    1,359
    I experienced this if the Driver Demand tables were highly modified. Could have been a coincidence but that was the only time I ever experienced it early in my Gen V tuning days.
    [email protected]
    Owner/GM Calibrator
    Quote Originally Posted by TriPinTaZ View Post
    Same here. I put the driver demand table back to stock and it went away
    Jul 2018
    10
    I've also been told that you have to run the stock driver demand tables, but then the revs still hang somewhat when revved in neutral.
    Jul 2015
    19
    i ran into this when maxing the axle TM values; also had success massaging the virtual torque and driver demand tables in that region
    Oct 2016
    40
    try reducing driver demand in the idle section(top left) just experienced the same issue 3 days ago.
    Jul 2018
    10
    Still having this issue. I tried adjusting external idle load and it seemed to have mitigated it a little. When you say reducing these driver demanded torque, you mean increasing the absolute values of the negative numbers?
    https://imgur.com/GD11vPV
    That's the stock driver demanded torque. Throttle input versus VSS/RPM. As 0 by 0 it's 56. Beyond that it's -41, -121, -175. So what would you recommend?
