Results 1 to 9 of 9
Thread: P0068 at idle and shutting down fuel system
    Jan 2018
    6
    2006 6.0l LQ4, I had a good working sd tune before I needed to pull the engine for repair, installed BTR Stage 3 turbo cam. Now it runs at idle for about 30 seconds and will die and not restart, fuel pump will not even turn on until codes are cleared then will start and idle fine for 30 seconds again. I've maxed the P0068 error table (4.10) and added to idle air mass table (13+), idle set to 950 rpm runs perfectly right up to when it dies. It fails the maf like always and the only other code is p0106 for map sensor range. Clearly I'm missing something?
    Aug 2009
    Calibrating
    3,376
    Post the tune
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jan 2018
    6
    This is the current tune
    Jan 2018
    6
    Any thoughts anyone?
    Dec 2013
    23
    I had a similar problem with a 2004 6.0 and the similar p1514 code, I ended up just disabling the code and it fixed it, hoping that after i get the tune dialed in i can create a histogram for that table and set it back up just for peace of mind. From what I understand its just a sanity check on the electronic throttle body.
    Jan 2018
    6
    I tried to disable the suspect codes and no change, failed ecm maybe?
    Waldorf MD
    774
    The P0068 code is not disabled in the tune file you posted.
    Daily Driver= 2003 BMW 330xi
    Jan 2018
    6
    No but when I disable it nothing changes, could it be something that needs to be changed in the P106 error map calculations min/max? I threw in another ecm and flashed it with exactly the same results so now I know for sure its tune settings and not a hardware failure.
    Jan 2018
    6
    Ok finally some progress! I disabled both the P0068 and P0106, now the car stays running without problems. Is there any problem running it this way or do I need to dial something in with it for safety?
