2006 6.0l LQ4, I had a good working sd tune before I needed to pull the engine for repair, installed BTR Stage 3 turbo cam. Now it runs at idle for about 30 seconds and will die and not restart, fuel pump will not even turn on until codes are cleared then will start and idle fine for 30 seconds again. I've maxed the P0068 error table (4.10) and added to idle air mass table (13+), idle set to 950 rpm runs perfectly right up to when it dies. It fails the maf like always and the only other code is p0106 for map sensor range. Clearly I'm missing something?
