ahh my bad, saw ID1000's mentioned and...brain fart lol
Not quite as big as mine using ID1k data from my car in this tune lol
I would guess a bad barometric sensor, it got missed in the write calibration, or its unplugged. It was changing in your last log. Your baro reading is flat down to 4 decimal places. I suspect its using the default baro value. Your enable load tables are limiting your VCT modes, but it should still show different modes(stability/drivability) when the criteria is meet.
I'm seeing max load in SD as 107kpa along with a lot of other things Max map vs airmass 31inhg that i always assumed needed to be raised when going into boost? Map max delta above BP is zero? Does it not matter what those are once cylinder air anticipation is disabled?
I have max load set to 2, MAP vs airmass at 90 inches of mercury, Map max delta was left alone and Load at WOT is scaled to 2 in the higher areas as to not hit a limit. But car is logging load correctly and doesn't seem to have any issues.
Something has to be corrupted somewhere because the IAT reads as it should on the stock tune, but as soon as I flash it, it goes haywire.
Cams were working as they should in the flash just before this. I'm going to try a "write entire" to make sure something didn't get missed or corrupted. This car has been one corrupted mess after another. It was traded into a dealership with a boss intake, BBK TB, longtubes, stock cats, and a CAI with the stock tune on it. A friend bought it and purchased a TVS kit for it. I installed the TVS kit for him, and I'm now doing the tune.
