Results 1 to 15 of 15
Thread: Help Plz: Start up on L99 after adding supercharger - lots of codes
    Feb 2018
    8
    After a long upgrade project on my 2010 Camaro SS L99. I'm getting some major codes.
    If I let the car charge overnight I can get it to idle for 10 min before it dies. Then it dies almost right after crank up.
    Too many codes for me to chase to figure out what is wrong. I'm thinking this might be due to a bad ground. But any help on where to start the trouble shooting would be greatly appreciated.
    Below are the codes I'm getting after it dies out
    0x7E8: P0036 - HO2S Heater Control Circuit (Bank 1, Sensor 2) (Pending, Current, Old, History)
    0x7E8: P0050 - HO2S Heater Control Circuit (Bank 2, Sensor 1) (Pending, History)
    0x7E8: P0056 - HO2S Heater Control Circuit (Bank 2, Sensor 2) (Pending, Current, History)
    0x7E8: P0059 - HO2S Heater Resistance (Bank 2, Sensor 1) (Permanent)
    0x7E8: P0102 - Mass or Volume Air Flow A Circuit Low (Permanent)
    0x7E8: P0202 - Cylinder 2 Injector Circuit / Open (Pending, Current, Permanent)
    0x7E8: P0204 - Cylinder 4 Injector Circuit / Open (Pending, Permanent)
    0x7E8: P0206 - Cylinder 6 Injector Circuit / Open (Pending, Current)
    0x7E8: P0208 - Cylinder 8 Injector Circuit / Open (Pending)
    0x7E8: P0700 - Transmission Control System (MIL Request) (Pending, Current)
    0x7EA: P2534 (Pending, Current, Permanent)
    Aug 2009
    Calibrating
    3,373
    Don’t run it anymore... has to be a ground!! Half the injectors probably aren’t firing.....
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Feb 2018
    8
    Quote Originally Posted by Ben Charles View Post
    Don?t run it anymore... has to be a ground!! Half the injectors probably aren?t firing.....
    That was my thought too. I've been looking all over trying to find a ground I missed putting back, but can't find any that are not solid. Any thought on what ground all passenger side injectors are grounded at?
    Tuning Addict
    Jan 2015
    6,813
    Check the ecm fuses in the trunk? Grounds are on the rear of each head - one at right lower corner of passenger head and then driver's may or may not have two on the rear of it... Really sounds like a fuse though with heater circuits and an injector bank...
    ~Greg Huggins~
    Feb 2018
    8
    ECM fuses in the trunk are good. That was a good thought tho. I did not think about the trunk fuses.
    Feb 2018
    8
    Quote Originally Posted by BrettJStewart View Post
    Found the main front ground wire a little loose. (If I pulled on it I could get it to turn) Tightened it up. but still not change in running. The codes went down in number. But I'm still lost here.
    Now the only codes showing are below: (about 1/2 as much as before)
    0x7E8: P0202 - Cylinder 2 Injector Circuit / Open (Permanent)
    0x7E8: P0204 - Cylinder 4 Injector Circuit / Open (Permanent)
    Dec 2008
    Nevada
    4,452
    check your power leads as well. had a no start at sonoma raceway all because the battery cable at the alternator feed junction (truck motor) had come loose and wasnt letting enough current flow through to power the ecu.
    it has to be a power or ground junction as the codes that do occur receive one or the other from the ecu. you just need to find where the circle of flow is broken.
    Feb 2018
    8
    Quote Originally Posted by cobaltssoverbooster View Post
    Thanks for the advice. I'll have to wait till next weekend to try and trace the power side. (gotta get ready for a work trip on Monday) I'll post on here if I get this thing figured out next weekend.
    Thank you all for your suggestions. I'll keep hunting till I find it.
    Dec 2013
    23
    Looks more like bad power wire, the injectors are grounded through the ecm to trigger them, the other side of the coil just goes straight to keyed power.
    Tuning Addict
    Jan 2015
    6,813
    Yeah, that's why I said to check the ecm fuse in the trunk - it powers all of those injectors, but if you weren't working in that area? Did you take the battery junction block apart? If you did, take it back apart and make sure all of the connectors are fully seated via their retaining latching bolts and no pins backed out or bent over... Also make sure the main power connection on the driver's side fender is tight and the smaller connectors on the upper side of the fuse block are seated - had one that wouldn't fire at all where that connector never latched fully (the smaller one above the fuse block that has a scissor latch setup)...
    Main thing is to just keep it simple - retrace whatever you took loose and had to reattach
    ~Greg Huggins~
    Feb 2018
    8
    Well...After another day of troubleshooting I'm about to give up hope on this one. I double checked all grounds (good) I checked resistance on the injectors (tested good 12.5 ohms), I tested keyed on voltage at the injector (12V all good), I checked the driver circuit from the ECM with a test light (flashes indicate its sending a good signal), I put in a diode across an injector harness (flashed indicates its sending a good signal). SO if injector is good, ECM is good, and wiring is good. What the heck is going on here? Anything else I can try here?
    Feb 2018
    8
    I'm not only getting the following codes, but car shuts down 2 seconds after crank.
    13,565
    2 seconds after crank sounds security related if it's running and then dies.
    The other codes could just waiting for a few drive cycles to clear being that they are permanent codes.
    Feb 2018
    8
    Would you recommend removing the VATS and re-flashing?
    13,565
    It wouldn't hurt if you had too. Being that the VATS tabs are in the OS tab you have to write entire for it to take.
    I can't say that's exactly what is happening but from previous stuff in the past the 2-3 seconds of run time and then it cutting off tends to be the security system shutting it down in many cases.
