ok so im doing a LS2 swap in a 2000 camaro. the engine is a 6.0 lq9 with flat top pistons, 799 heads and .040 head gaskets. pretty much set up to run 11.5:1 compression ratio. the cam is a LS7 stock grind. stock rockers with trunion upgrades. ported ls2 intake with 90mm cable TB. i plan on running stock camaro ecm setup for manual(car is gonna be a auto with a tci EZ TCU controlling it) it will have a volant cold ai and long tubes as well. my issue is i NEVER tuned anything in my life! so what version do i need? what wideband? what version of hpt do i need for the wideband to be logged? were can i learn more? i am completely in the dark here lol. thanks for any help in advance!
