load with failed maf limits
ford ecu's in the program allow for a max load of 4.00 under airflow, speed density, max load. The load with failed maf only allows 1.99. when trying to set past the 1.99 an error message appears, anyone ever go past 1.99?
Because 2.0 is max LOAD for speed density. Why even go so high? Just lower the cylair multiplier and problem solved
I want it as a like a secondary in the event of maf failure so the car will still run and correctly. which one would it be the WOT or MAX, ill try it and see what happens.
another reason is because if I turn on anticipation logic function it takes from that and runs lean. I would like to use it again if I can. this is a turbo car with a healthy amount of boost.
