I have this 97 Chevy truck in the shop. Someone else did the swap and someone else provided the base tune. This is first 411 swapped vehicle I've tuned. Fixed a bunch of problems with the truck, broken valve springs, 02's, etc.
It's a 383 with an unknown cam, LT headers. Stock spider intake.
This is the 1st vehicle I've ever had to drill a hole in the T/B to get enough air to idle properly. Started out idling at 75 kpa. Played with fueling, didn't help. I tried opening the T/B blade first like usual but it needed more air. Slowly increased the hole in the TB and now it's idling at 49kpa. IAC counts are decent, will probably have to mess with the Effective IAC Area table now.
Anyhow, trims are decent at idle, as soon as you get off idle it's adding a ridiculous amount of fuel. The VE table is just a base and normally have to take fuel out. There is no way this needs that high of VE at part throttle and cruise.
I changed the cylinder litres to a 383(it was still for a 350)and that didn't make any difference. I looked at the injector data and compared it to some of the tunes in the other 411 thread and they seem to be OK.
I verified fuel pressure and it's good. I checked the cam offset angle and found the dist. was a tooth off. I fixed that, now it's .5-1.0 degree.
Can someone take a look at the tune and see what I have over looked?
