Pretty simple question,how do I go about using an 05 411 in my 2000 2500hd. I just want to get away from the two VE tables and go for a 411 with a single VE table
My biggest concern is being able to tune for cable throttle,and are the pinouts different
I believe your 2000 has a 9354896 PCM and from what I have read, it will suopport an 0411 OS like the 12212156 which has the single VE table...Not 100% sure so hope someone with experience in this swap chimes in. They all support DBC and DBW as well. If so, then a write entire is needed with a donor file from the repository or GM Tech II at dealer....but make sure it is a pure stock file....you will have to relicense as well.
subscribing
Ed M
[email protected]
Thank's ED, I just want the newer op system because it's easier to achieve what i want with more tables
Was sitting here thinking,is it possible to just install the OP system I'm looking for into my ecm?
Yes, that is what I believe, but was hoping someone who has actually performed that swap would chime in just to be sure....
Ed M
[email protected]
