Results 1 to 5 of 5
Thread: No log for afr error at WOT?
    Jun 2010
    559
    I cant log my AFR Error at WOT, What its missing something?
    I'm still working on the layout, got the cruise mode to work properly but cant log WOT.
    13,564
    I didn't look at your layout but are you sure you are logging every channel required for your graphs?
    I don't see cylinder airmass in there for one, for like logging timing and knock.
    Also you can not tune this thing with the IAT sensor unplugged, you will be getting completely incorrect readings if the IAT is not working.
    Jun 2010
    559
    I haven't got cylinder airmass, My cruise mode work i have to be missing something for WOT...
    13,564
    That is what I don't get, if you created the AFR error to log while cruising it will still log the AFR error when you are tuning WOT.
    Cylinder airmass is available on any LS engine for a channel. You have to search for it or type it in to find it.
    Follow this write up if you have any issues.
    https://forum.hptuners.com/showthrea...al-VE-Vehicles)
    May 2016
    Adelaide, Australia
    246
    I also haven?t looked at the files, are you using a wide band?
