Results 1 to 13 of 13
Thread: Quick LC-1 wiring question
    I wired it up like in the sticky,
    Can I have my lamda controller permanently wired in to the cig lighter?
    (im using it as a narrowband also)
    Or I better have a power switch installed?
    www.turbofirebird.com tuned with HPT MPVI Pro, LC-1.
    Senior Tuner S2H's Avatar
    Apr 2005
    4,387
    you can..but you will want to wire a switch to turn it off when the car is not running...
    smarter to wire power over to a switched on spot in the fusebox and then wire heater ground to where ever you can find a good ground
    -Scott -
    what switched off spot are you talking about?
    Also does power remain in the cig lighter after car goes to the Power Saving Mode?
    Apr 2005
    4,387
    on the fuse box in th eside of your dash in your 98 bird...there is an open spot that is only on when the key is on...this is your best spot...couldnt tell you offhand which one it is...you can do trial and error...plug it in..key off..if you have power find another one...when you find one that doesnt seem to have power switch your key on and see if you get power
    cig lighters are on all the time on f-bodys...no powersave there
    -Scott -
    got it. Is it kind of bad when LC1 is all the time on?
    Also Ive got an extra connector for Automatic transmission in my center console , wounder if that woud be good power sourse?
    Apr 2005
    4,387
    yes its bad when its on all the time
    once I accidentally left mine on all night..next day it was worthless...
    -Scott -
    What output resolution should I use for v6?
    1/12 , 1/6?
    Apr 2005
    4,387
    its not based on what engine you have,....
    its based on how fast you can collect data...
    you should set it at 1/12
    -Scott -
    Analog1 and Analog2? or just wideband (analog2)?
    Apr 2005
    4,387
    wideband to 1/12
    narrowband to 1/6
    -Scott -
    also can I keep LC-1 Serial IN plugged with that plug all the time? Or it just for programming abilities?
    Apr 2005
    4,387
    yeah..no problems with that...mines plugged up all the time
    -Scott -
    Dec 2005
    Sweden
    267
    You shouldn´t let the WB heat up before the engine is started, right?
    Black Pontiac Trans Am WS.7- Runs on E85
    And soon to be powered by Twin Turbos.
    How to run your LS1 on E85
