Is there a way to determine if I've out flowed my MAP on my MAF sensor. I was doing some pulls the other day and noticed that my MAP went to 120kpa and flat lined after that. The fueling looks good, timing is good but my MAP seems to flat line for the remainder of the pull. Is there where the VE tables kick in or is this sign that i need to raise the limit on my MAP. I've attached a copy of the runpPlease advise
