Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: 2011 GT500 MAF Transfer data
    Feb 2018
    21
    I'm looking for stock MAF transfer curve data. My car came with a tune and we believe its tuned for an aftermarket intake but has the stock intake on it now. Trying to find some stock numbers and adjust from there. Thanks.
    2011 SVTPP GT500
    Jul 2017
    529
    Here's the tune from my stock 2010 GT500, should be the same as 2011.
    Sep 2010
    872
    Quote Originally Posted by MRRPMBRP View Post
    won't work, 2010 uses volts not MAF period. 2011 and up GT500 use MAF period like Coyotes do. 07-2010 use the voltage table instead
    Jul 2017
    529
    Ok, I thought the period started in 2013, I haven't tuned my 2010 yet, so no experience with the way the fuel is tuned.
    Feb 2018
    21
    I appreciate the attempt and info. Anyone else? Thanks in advance.
    Feb 2012
    TEXAS
    636
    Gt 500 maf 2012
    2012 gt500 stock maf
    Feb 2012
    TEXAS
    636
    Gt500 maf
    Quote Originally Posted by mstang_man View Post
    2012 gt500 vjko stock maf
    Feb 2018
    21
    Thanks! What does the VJK0 stand for?
    Feb 2018
    21
    So when comparing the curves, the curve for my car varies slightly from your second file. Ive compiled them in a file.
    Feb 2012
    TEXAS
    636
    box code from ford, 4 digit code on pcm
    Jul 2017
    529
    Are you doing anything with the speed density tables on the GT500?
    My 2014 I haven't figured out how to tune those yet, plus it has a table that I haven't seen in anything else, nobody knows anything about.
    Feb 2012
    TEXAS
    636
    whats you strategy for the 2104 shelby gt500
    Jul 2017
    529
    If you mean me, not sure, how would I know?
    Feb 2012
    TEXAS
    636
    either when you plug in the scanner and view vehicle information, or look at the PCM there shoud be 2 sets of number/letter combinations one id ford part number the other should be a 3/4/5digit number and letter combo like the 2012 pcm VJK0
    Jul 2017
    529
    See if these pics show the strategy
    Feb 2012
    TEXAS
    636
    FGFC3B5 is ARL5
    Jul 2017
    529
    FGFC3B5 is ARL5
    Ok, thanks. What does that tell me?
    Feb 2012
    TEXAS
    636
    well your strategy is FGFC3B5 and the 4 digit code should be ARL5 on the pcm, helps if you need to replace pcm, and and this is mainly how SCT catalogs the Vehicles if you ever use SCT
    Jul 2017
    529
    Ok, this is actually a different PCM from Ford, original one was/is locked by a tuner when I got the car, other tuner wanted $150 to return to stock, a new pcm was only $250, so I did that.
    ANy input if I need to tune the speed density tables? Nobody seems to know anything about the speed density on GT500, only the Coyotes.
    Feb 2012
    TEXAS
    636
    volumetric efficiency correction under boost
    max MAP based on airflow
    Maximum MAP
    set MAX MAP Counts to 1020
    set max load seen by engine 3
