I'm trying to figure out why I'm getting so much knock retard and how to fix the problem? Knock sensor has been replaced also
mikes tune log.hpl
mikes tune log.hpl
Yeah, that's not normal at all.
Were they replaced with factory AC Delco parts and torqued to the proper spec??
Are you positive that nothing is rubbing on anything and that the motor mounts are completely shot?
Just throwing idea's out there because it's even showing crazy knock just at idle.
