Results 1 to 2 of 2
Thread: E38 Rear O2 and Cat delete
    Apr 2007
    Los Lunas, Avondale
    78
    Are there any extra steps needed to delete cats and rear O2s?
    2012 Camaro SS 6.2L E38 I believe.
    They keep causing check engine light and DTCs in the scanner.
    I have attached some an image of what I'm seeing. The thing I've never seen before is the permanent thats there.
    What am I missing?
    Thanks everyone.
    2002 NBM WS6
    APS F-BODY TWIN TURBO KIT
    317 Heads
    60# Mototron Injectors
    HPTuners tuned by Sean@Solid-Technology, Abq NM
    610 RWHP DYNOJET on 7.9PSI
    13,565
    Permanent codes do not clear, it's why they are permanent.
    You can disable the DTC"s by setting them to no error reported and disable the SES light but it will always show up as a permanent DTC. Sometimes some of them go away after tons of drive cycles.
    You also need to disable the cat test and post o2 sensor test within the tune when you delete those parts.
