Results 1 to 13 of 13
Thread: need base tune for truck Gen 3 5.3 w/ 799 heads and BTR NSR (no springs required) cam
    Aug 2015
    3
    need base tune for truck Gen 3 5.3 w/ 799 heads and BTR NSR (no springs required) cam. any help is greatly appreciated
    Aug 2015
    3
    cam specs are: 224/230 @ .050 duration , .500/.500 lift @ .050
    13,533
    Your stock tune is your base tune.
    Everything will be specific to your vehicle tuning wise. All airflow and fuel calculation are specific to the engine so you will need to tune it starting from stock.
    Grab yourself a wideband AFR gauge and start picking away at it.
    Aug 2009
    Calibrating
    3,371
    Just did that setup about a week ago!! Setup sounded good
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Aug 2015
    3
    I meant a base tune for the cam that I can start and go from there with
    13,533
    Yeah, that would be your stock tune.
    It's not really possible to predict the fueling/airflow changes required for your specific engine. Nobody will have an exact plug and play data unfortunately. Starting the stock calibration is best.
    It will run and drive on a stock tune, that won't be an issue. It's the final details that you will be fixing. Start with getting your Primary VE and MAF curve in check. Then work on idle and timing adjustments and WOT fueling and timing last.
    Also if you are running factory 25lb/hr injectors you may not be able to do much at WOT, they may not have enough head room with the cam upgrade.
    i have the exact setup but im still working on mine, still learning.
    2001 3.8 v6 camaro, T5, ford 42lb green top injectors, grand national .63 a/r turbo. 8psi. stock motor, ngk tr6 plugs (one step colder) 91 octane.
    2001 4.3 zr2 s10. daily driver, 31" tires, 4x4, cat! and exhaust. looking for mpg.
    Aug 2009
    Calibrating
    3,371
    The factory injectors ran out of fuel around 5400rpms with 241 heads targeting .85 lambda
    14 Gen 5 Viper
    i haven't even gotten to PE. thats crazy.
    Hey Ben, do you mind sharing your file? i'm having some idle issues and i think it may help to see yours. i'm sure it'll be considerably different because im running different heads but still helpful. Whenever i goose it and let go in drive it dies or tries to when i lift my foot. not sure what the culprit is yet.
    Apr 2019
    4
    Have the same set up and will be happy to share when I get it dialed in. Would also like to see others to learn and compare.
    Sep 2017
    14
    Quote Originally Posted by Fulroddle View Post
    any update on this tune?
    Nov 2021
    Did you ever get yours dialed in? Having an idle issue
