Results 1 to 5 of 5
Thread: Relearn after 6L80e Rebuild?
    Jun 2016
    11
    Is the Fast Relearn all that I need to do after rebuilding a 6L80e? Vehicle is a 2012 Camaro SS, stock trans rebuild, stock converter and I'm unclear if I need to send it somewhere to reflash or if I can get away with just doing the Fast Relearn or another procedure in HP Tuners. Thanks in advance.
    Matt
    Jan 2004
    Perth - Western Australia
    276
    do a clean, then do a fast learn.
    Jun 2016
    11
    Update: Can't get the Clean, and a Fast Relearn to Complete. Says "Temp Lo" when I try to complete either. Both are within range. Any Ideas?
    Dec 2017
    29
    weird your trans temp is above 70c, i have seen others say even when its up to temp it wont work if you tried it before it was hot enough try again when it hits like 80c but dont attempt to learn until it hit that temp.
    also here is guide https://forum.hptuners.com/showthrea...ght=fast+learn 96c might have been to high it says 70c - 95c
    Jan 2004
    276
    you can change the temp that it allows the clean to happen. atleast you can in efilive. i havent checked if hpt can do it.
