Results 1 to 11 of 11
Thread: Holley 66lb Low impedance injectors in a 411 LS1 application...?
    Feb 2017
    miami
    1,799
    Hello, this is my first time every buying new injectors for something I own. I Really want holley 66lb/hr but I see they are low impedance. Can I simply add 10ohm resistors to 1 wire of each injector?
    13,564
    Not worth the hassle.
    The computer can not properly control low impedance injectors.
    But injectors from ID, FIC or Deatchwerks that are known good injectors.
    Dec 2008
    Nevada
    4,452
    no they have a different driving method than high impedance injectors so just throwing resistors at this wont work.
    high impedance = saturated
    low impedance = peak and hold (high amp opening and low amp sustained spray)
    Feb 2017
    miami
    1,799
    thanks guys!. Wow so Holley doesn't sell anything to work in oem ecu after like 50lb!
    Dec 2008
    Nevada
    4,452
    Best cheap option is seimens deka 60's, 43.5 psi Ford blue Giants, or I would personally go to FIC 650's. IDs smallest is a 750 iirc, and may be a bit much if your already factoring the overhead properly for the 60 lb/he requirement you seek.
    Feb 2017
    miami
    1,799
    So how about these:
    https://www.ebay.com/itm/Set-of-8-1-...4383.l4275.c10
    With brand new ford injectors 50lb:
    https://www.ebay.com/itm/2013-2014-F...72.m2749.l2648
    Half the price of FIC
    Dec 2008
    Nevada
    4,452
    Feb 2017
    miami
    1,799
    Thanks, I assume thats some tasty data
    Dec 2008
    Nevada
    4,452
    its the data for those injectors with non-referenced regulator units which was the common stock fuel rail application with 58 psi source.
    Apr 2020
    1
    Hi....I'm using the injectors that were supplied with the Mass-Flo system that I had installed years ago. They are 36 lb/hr injectors, but no where in any documentation can I see if they are considered high or low impedance. I connected my Fluke 23 across the terminals on one of the injectors and it displays 17.4, where does that reading fall in the scale of high or low?
    cheap pcb assembly
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by BibbieMok View Post
    Those are high impedance injectors.
