I'm setting up a wideband in VCM and I'm pretty sure I got it right. Just a few questions running my LC-2 over analog.
When I transform I use eq ratio to run lambada. Under function it says (v/5) + .05 = output
I'm assuming this is the correct function and I do not have to create a user defined parameter?
I noticed every other wideband has a different function most likely per manufacturer, so I assume this is the correct one for mine?
Also when I set up my graph and error I know what axis I use but for high , mid and low do i input my lowest lambda i plan on reading, mid as 1.0 and my high as what my highest lamabada I want to record?
Thanks in sure I'll have more questions.
Bobby
