Ford tuning table axis extrapolation?
What happens when a tuning table runs out of values? For instance in this 'Boost time table' The RPM Axis only runs out to 1250RPM What does the ECU/TCU do when it sees 2000 or 3000RPM?
Does it "see" that the table was linear and just continue with the same value
Does it use a 0 value?
..or something else?
I believe it just uses the last value. But I'm not sure. You could change the axis to be a useable value and see if it changes
