Originally Posted by
misk
I haven't been able to test this yet, but try splicing your reverse light out to the reverse light pin on the ecu. fgs do funny things when theres no reverse light signal at the pcm, I assume itll be looking for like .5v as a way of knowing the switch is hooked up.
in saying that, you can actually leave the auto enabled and increase the torque limits for any trans fmem tables as well as raising neutral rev limits and editing some torque management settings.
doing this is also stops it from going into limp mode after 10-15min with no speed source.
another thing to look at is your pedal settings. some pedal settings just wont work in a conversion. copy the entire throttle page from another fg tune that has different settings.
