Results 1 to 5 of 5
Thread: How to log e85 fuel error?
    Jun 2010
    559
    I just set up my scanner how schpenxel post it in the sticky, works great. Well I have a car here switch to e85 2001 camaro. Well since the file it?s 9.7 on the stoich airfuel, my ngk its reading 14.7 stoich so it?s throwing off my fuel error. What can I do or what I need??
    13,581
    Lambda.
    Use lambda error or EQ Ratio Error as that's the other wording for it.
    Disregard AFR with E85.
    Jun 2010
    559
    Using that I will able to just copy and paste by % even my ngk its reading 14.7?
    13,581
    It doesn't matter what the gauge says so long as what you are logging in the scanner is lambda.
    You should be able to choose the readout with most widebands, right click and choose lambda instead of AFR. If you can change the gauge to read in lambda too, that would be helpful.
    Jun 2010
    559
    Ok, tomorrow morning I?ll give it a try.
