I am having an issue with the idle quality.
When started it will fire and idle for about 3-5 seconds then die.
If I start it and give it light throttle for about 5-10 seconds it will idle when I let off the throttle.
Is this normal for a large cam? I would like to be able to use my remote start again.
I am using ANN enabled and running 52# DW injectors.
Is there a "pedal adder" similar to a high idle function?
Motor is 6.1 based 426 NA swapped into a 2010 R/T
