Hi guys, I got into this job after a local dyno tuner worked on it for 3 days and gave it back to the owner, incomplete.
Car is a 10 Camaro SS with an LSA blower, long tubes, cats deleted, JLT intake w/ LS3 MAF, thats it. Car runs, you can drive it. Made 530rwhp. But had crazy lean AFR drifts on some pulls, and rich drifts on other pulls. That's why the tuner kicked the job out.
I pull the attached tune out of the car and start looking at it, can anyone look at this and help me understand what is happening here?
Notable tables:
Gas PE EQ ratio 1.7 to 1.9????
MAF table (stock LS3 data) (JLT intake is larger diameter and should require MAF data change)
1 bar MAP data - he put the LSA ambient air pressure sensor in the manifold, and put the LSA 3 bar in the ambient position. Says the E38 will not read the 3 bar (false)
Is this a tuning technique I am not familiar with? PE table raping? My experience tells me to put final desired PE AFR in the EQ ratio table and tune the MAF and MAP for desired results?
