Just got the car tuned and trying to setup a good layout for datalogging. I've used the Boost Math parameter, but Im not sure if its setup right, because I'm only seeing around 2psi of boost, when I know the car is making about 10psi.
Can someone take a look at my scanner setup below and tell me what I'm doing wrong? If the log and layout files are needed, I can post them up also.
Stock MAP sensor
(my signature is old)
