Results 1 to 7 of 7
Thread: 275x55x20 Calibration?
    Tuner Lucky13MN's Avatar
    Feb 2006
    Minnesota
    57
    Hey all, I'm a newbie tuner and trying to figure out what to put in for my summer wheels.
    During the winter I run 265x75x16's and in the summer I run 275x55x20's, funny thing is (according to my GPS) it's pretty accurate as-is with no adjustment, but if I do put in the diameter according to a tire size calculator it throws it off a bit more.
    Just wondering if I should leave it or what's going on? The stock setting is something like 30.8 while the 20's are 31.9, so there is a noticeable difference there.
    Here's the site I'm using:
    http://www.miata.net/garage/tirecalc.html
    Suggestions/comments?
    2001 Silverado Z71 4x4
    5.3 with Stock 4L60E
    Z06 Cam, S&B Intake, JBA Headers, Magnaflow Cats, Corsa Cat Back, LS1 Fans, Tuned with HP Tuners.
    Current Best: 14.92 @ 93mph
    Tuner dc96819's Avatar
    May 2004
    Long Beach Ca
    121
    The tire calculator is not very good.My 305/20 were way off.
    Try measuring the tire.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    you know theres a tire conversion calculator right in hpt right? http://www.hptuners.com/forum/showthread.php?t=5691
    Feb 2006
    Minnesota
    57
    Hey, I did not know that... thank you.
    That tool gave me the same output though, 31.9. Nice to know it's there... still confused on why my speedo is off with that number in there.
    Edit:
    Apparently the factory setting is for 245x70x16 or something (30.81)... according to that calculator:
    265x75x16 = 31.6
    275x55x20 = 31.9
    Now... that said, I know there's a lot more than .3" difference when they are side by side.
    I think I'll just have to use a level and get an accurate measurement to be sure and take it from there.
    Thanks guys.
    EDIT:
    Update... I measured the tires, 31 1/8" high, so I put in 31.12 and voila...spot on. I guess some things are just easier when you do the measurements
    Apr 2003
    Almost 2000 feet.
    7,876
    SS trucks have the same tire and it comes out as 31.04". Tire calculators don't take into account the weight placed on the tire "squishing" it.
    Always Support Our Troops!
    Nov 2002
    Central Florida
    2,503
    Do not believe any calculator based off the numbers
    stamped on the tire. The only thing you can trust is
    the measured circumference of the tire, drive over a
    tape measure and wrap it. Then you can divide by pi
    for the diameter, or whatever you need to enter in
    the speedo section to drive the auto-scaling.
    Apr 2003
    Almost 2000 feet.
    7,876
    You can also do a "roll out" by marking the tire & ground, rotating the drive wheel tire 1 revolution and measuring the distance. Then divide by Pi to get diameter.
    EC
