I doubt it, but reset all adaptives with the scanner to be sure.
When I primed mine I unplugged the fuse for the fuel pump and pulled 1 plug from each cylinder.
^ He is correct, only the exhaust cam tables are active. Are you using a VVT cam or is it locked?
