Originally Posted by
Hemituna
Ummmm.....no, HPt is way, way, way, way, way better than DS on these.
My daily is a whippled 15 SRT Jeep, nearly same spec as OP.
Did it also go wah wah wah when I first tuned it.....yes it did (DS & HPt).
Is it fixable.....yes it is and DS & detuning it is not the answer.
At part throttle you can bump into tq and airflow limits in the torque modelling.
So telling the PCM about the huge airflows you are now using is not smart.
It will limit the TB opening to keep the numbers where it wants them.
If you reduce pedal vs TB it just dulls the thing till you go WOT.
If you increase pedal vs TB, it will surge as it opens, gets shut down, opens again, gets shut down again etc etc....
The whipple likes to be fed lots of air so we need to rein in the airflow numbers to keep the PCM happy.
I forget where now, but in some of the OS's there is an airflow table that won't allow you to go higher than 511 or something.
So I now use that number as a guide to the max and then the ETC functions just as it should, totally tunable.
Cam timing is really important too as OE has it moving all over the place..even more critical if you have an aftermarket cam.
Attached tune is an example of where the numbers end up...and this one has a 92mm Hellcat TB.
